BookmarkSubscribeRSS Feed
cis_pete
Jan 26, 2015
Open color selection window by script / use Windows choosecolor dll
I would like to have the JMP color selection window to be opened by script. The color that is selected by the user should be returned (RGB-values).
So I would like to open these windows by script:
Is this possible? So far I did not find a way to do it (with JMP 12.1).
So I thought you could use a Windows dll. My problem is that I have no clue about how to use dlls ...
With the JMP scripting guide and syntax reference book and the internet pages mentioned below I created the following code:
user32 = Load Dll( "User32" );
user32 << DeclareFunction(
    "FindWindowA",
    Convention( STDCALL ),
    Alias( "FindWindow2" ),
    Arg( UInt32, input, "lpClassName" ),
    Arg( AnsiString( 200 ), input, "lpCaption" ),
    Returns( UIntPtr )
lpCaption = "Script - JMP";
hWnd = user32 << FindWindow2( 0, lpCaption );
user32 << UnloadDLL();
dll = LoadDLL("C:\Windows\System32\comdlg32.dll");
dll << Declare Function(
    "ChooseColorA",
    Convention(STDCALL),
    Alias("ColorPalette"),
    StructArg(
        Arg(UInt32, "lStructSize"),
        Arg(Int64, "hwndOwner"),
        Arg(Int64, "hInstance"),
        Arg(UInt32, update, "rgbResult"),
        Arg(AnsiString, "lpCustColors"),
        Arg(UInt32, "Flags"),
        Arg(Int64, "lCustData"),
        Arg(Int64, "lpfnHook"),
        Arg(AnsiString, "lpTemplateName"),
        update
    Returns(Int8)
selected_color = 5;
hwnd = 0;
size = 36    ;
result = dll << ColorPalette(
    size,        // lStructSize
    hwnd,        // hwndOwner
    0,            // hInstance
    selected_color,    // rgbResult
    "",            // lpCustColors
    2,            // flags;    2 = show all colors
    0,            // lCustData
    0,            // lpfnHook
    ""            // lpTemplateName
show(result);
dll << UnloadDLL();
This code is not working, the color selection window is not displayed but the result from the call of the ColorPalette function is always zero.
I think one problem is that I don't know the correct value for 'lStructSize'. I tried every value from 1 to 10000 without any change. So obviously there are more errors in my code (as I said, I have no idea how to use dlls).
Can anybode help?
Here are some (maybe helpful) links:
https://msdn.microsoft.com/en-us/library/ms646912%28v=vs.85%29.aspx
https://msdn.microsoft.com/en-us/library/ms646829%28v=vs.85%29.aspx#choosing_color
https://msdn.microsoft.com/de-de/library/windows/desktop/ms646830%28v=vs.85%29.aspx
And here is some VBA code that works in MS Excel (slightly modified code I found in the internet). I tried to do it in JMP similarly.
Option Explicit
Private Type CHOOSECOLOR
    lStructSize As Long
    hwndOwner As Long
    hInstance As Long
    rgbResult As Long
    lpCustColors As String
    flags As Long
    lCustData As Long
    lpfnHook As Long
    lpTemplateName As String
End Type
Private Declare PtrSafe Function ChooseColorAPI Lib "comdlg32.dll" Alias _
"ChooseColorA" (pChoosecolor As CHOOSECOLOR) As Long
Dim CustomColors() As Byte
Sub test()
    Form_Load
    Dim cc As CHOOSECOLOR
    Dim Custcolor(16) As Long
    Dim lReturn As Long
    cc.lStructSize = Len(cc)
    'Debug.Print cc.lStructSize
    cc.hwndOwner = Application.Hwnd
    cc.hwndOwner = 0
    cc.hInstance = 0
    cc.lpCustColors = StrConv(CustomColors, vbUnicode)
    'cc.flags = 0
    cc.flags = 2     ' all colors
    'cc.flags = CC_FULLOPEN
    lReturn = ChooseColorAPI(cc)
    If lReturn <> 0 Then
        Dim Farbe, Rot, Gruen, Blau As Long
        Farbe = cc.rgbResult
        Rot = Farbe Mod 256
        Farbe = (Farbe - Rot) / 256
        Gruen = Farbe Mod 256
        Farbe = (Farbe - Gruen) / 256
        Blau = Farbe Mod 256
        MsgBox "Color: " & cc.rgbResult & vbNewLine & "Rot: " & Rot & vbNewLine & "Grün: " & Gruen & vbNewLine & "Blau: " & Blau
        CustomColors = StrConv(cc.lpCustColors, vbFromUnicode)
    Else
        MsgBox "User chose the Cancel Button"
    End If
End Sub
Sub Form_Load()
    ReDim CustomColors(0 To 16 * 4 - 1) As Byte
    Dim i As Integer
    For i = LBound(CustomColors) To UBound(CustomColors)
        CustomColors(i) = 0
    Next i
End Sub
Tim_Tsai
Jun 13, 2014
Re: Open color selection window by script / use Windows choosecolor dll
I had same requireements.  Thanks, your sample code.  I revised it and passed the test in JMP 12.
Here is my script
ChooseColor = Function( {intColor, flags=3},
	{Default Local},
	If( Host is( Windows ),
		dll = Load DLL("C:/Windows/System32/Comdlg32.dll",  Quiet );
		dll << Declare Function( "ChooseColorW", Convention(STDCALL), Alias("PickColor"),
			StructArg(
				Arg(Int64,  "lStructSize"),
				Arg(Int32, "rgbResult"),
				Arg(AnsiString(64), "lpCustColors"),
				Arg(Int64,  "Flags"),
				Arg(UnicodeString, "lpTemplateName"),
				Update,
				"CHOOSECOLOR"
			Returns(Int32)
		lStructSize = 72;
		hwndOwner = 0;
		lstRGB = As List( ( Matrix( Color To RGB(intColor) ) * 255 ) );
		hexRGB = Concat(Substr(Hex(lstRGB[3], "integer"),7,2), Substr(Hex(lstRGB[2], "integer"),7,2), Substr(Hex(lstRGB[1], "integer"), 7,2));
		rgbResult = Hex to Number( hexRGB );
		lpCustColors = Repeat(Hex To Char( "FFFFFF00" ), 16);
		lCustData = 0;
		lpfnHook = 0;
		intRc = dll << PickColor(lStructSize, 0, 0, rgbResult, lpCustColors, Flags,0,0,"");
		If(intRC == 0,
			Return(intColor)
			hexRGB = Hex(rgbResult, "integer");
			Return( RGB Color( Hex to Number(Substr(hexRGB,7,2)), Hex to Number(Substr(hexRGB,5,2)), Hex to Number(Substr(hexRGB,3,2) ) ) );
		dll << Unload DLL();
