BookmarkSubscribeRSS Feed
sornasst
Community Trekker
Feb 2, 2016
Oneway T-Test Script: Truncated Journal Output
Hi, here is a follow up to yesterday's question regarding a script running multiple Oneway t-test using a "Where" clause.
The following script does almost the right thing but the headers for each subset do not appear in the Journal.
Names Default to Here(1);
For(i=92, i<= N Col (dt),i++,
  ow = Oneway(
  Y( :Delta mRSS W24 ),
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
  Where( :(Column (i)) == 1 )
  report(ow) <<journal;
  ow = Oneway(
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
  Where( :(Column (i)) == 2 )
  ow = Oneway(
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
  Where( :(Column (i)) == 3 )
OUTPUT FROM THE SCRIPT (One item)
DESIRED OUTPUT (Manual analysis; NOTE the Header Bar containing the Subset being considered):
Jun 22, 2012
Solution
Re: Oneway T-Test Script: Truncated Journal Output
before you send the report to the journal, just add in a statement changing the title for the Outline Box
  ow = Oneway(
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
report(ow)[Outline Box(1)]<< set title(
     report(ow)[Outline Box(1)]<< get title || "Tertile Log ADAM12 1 BASELINE = 1");
Jun 22, 2012
Solution
  ow = Oneway(
  X( :TRT01P ),
  t Test( 1 ),
  invisible,
