pawndreal_
Oneway Automate
Observation
Parameter_1
Parameter_2
Parameter_N
SETUP[EXP/CONTROL]
1
n
How do i automate the scripting of fit y by x by position?
my aim is to dynamically script thru all parameters for their correlation plots and append it to powerpoint?
Y: Parameter_1 [EXP]
X: Parameter_1[CONTROL]
Re: Oneway Automate
The JSL to perform what you want is pretty straight forward.  The only item of any complexity is the setting up of the list of parameter names and the control name.
names default to here(1);
dt=open("$SAMPLE_DATA/Blood Pressure.jmp");
// Get the column names
// As with your example, the last column is the control
colNamesList = dt << get column names(string,continuous);
// Get the name of the control column from the last element
// in the colNamesList
theControl = colNamesList[N Items(colNamesList)];
// Delete the control from the colNamesList
remove from( colNamesList, -1, 1 );
// Run the Analysis
biv = Bivariate( Y( eval(colNamesList) ), X( eval(theControl) ) );
biv << Save Presentation("$TEMP/Correlations.pptx", append);
open("$TEMP/Correlations.pptx");
