BookmarkSubscribeRSS Feed
One-sided error bars
My apologies if this is staring me in the face but I can't for the life of me see how to get JMP to output bar charts with one-sided error bars (just up).
Thanks.
mpb
Jun 23, 2011
Re: One-sided error bars
I'm not aware of any way to have JMP put out one-sided error bars in Chart. One possible workaround would be to make the bars be black, obscuring the lower part of the error bar, and specifying the appropriate error bar when requesting them. For example, if you want a 95% upper confidence limit then specify 90% for the 2 sided limit. You will also have to remove the statement which will refer to (in this case) the 95% confidence limits.
