Jackie_
Offsetting X and Y coordinates of wafer
I've two jmp table which has X and Y coordinates of the wafer. I would like to know if there's a way to align the coordinates of Wafer 1 with Wafer 2?
For examples: I want to align the following highlighted X and Y with the X and Y of wafer 2.
Wafer 1 : X, Y = 129, 372
Wafer 2: X, Y = -17, -15
I am not sure if there a way to recognize patterns in the graph builder and get the hover label information with JSL. Any suggestions would be much appreciated
Wafer 1 =
Wafer 2 =
Re: Offsetting X and Y coordinates of wafer
Yes!
This is a simple thing for JMP to do.  In fact, this little problem is a perfect li a great little project as your first JSL project.  The solution is to either add or subtract the difference between the maximum value of X Coord from Wafer 1 data table and Wafer 2 data table.  And then to do the same for the Y coordinates.
The script takes the following steps
Open the data table.  Here is the actual code for that
dt1 = data table("Wafer 1");
dt2 = data table("Wafer 2");
Next, to determine the offset difference between the 2 wafers, you need to find the Absolute differeence between the maximum value in the wafer 1 X Coord column and the maximum value in the wafer 2 X Coord column.
Now repeat the same for the Y Coord columns.
The next step requires the conditional determination of whether to add or subtract the offset value. A new column needs to be created that  if the X Coord column's maximum value for wafer 1 is greater than the X Coord column's maximum value for wafer 2, the offset needs to be subtracted from wafer 1's X Coord values.  If that is not true, then the offset is added to the X Coord values.
This step needs to be repeated for the Y Coord.
The reading of the Scripting Guide will give you the information on the data structures a programming features available in JSL.
15 REPLIES 15
It appears that if you add 89 to the X Coord and 58 to the Y Coord in the Wafer 2 data table, the wafermaps will align
Jackie_
I had to manually compare both maps to find the location of both dies in the map and the offset value. Is there a way to implement using jsl?
Yes!
Jackie_
Clear Globals();
Clear Log();
dt1 << New Column( "New_X", Numeric, "Continuous", Format( "Best", 12 ) );
dt1 << New Column( "New_Y", Numeric, "Continuous", Format( "Best", 12 ) );
Max_X1= Col Maximum(dt1:X Coord);
Max_Y1= Col Maximum(dt1:Y Coord);
Max_X2= Col Maximum(dt2:X Coord);
Max_Y2= Col Maximum(dt2:Y Coord);
Offset_x = abs(	Max_X2 - Max_X1);
Offset_y = abs(Max_Y2 - Max_Y1);
For( i = 1, i <= N rows(dt1), i++,
if( Max_X1 > Max_X2,
		Column(dt1, 4)[i] =  Offset_x  - Column(dt1, 1)[i] ;,
		Column(dt1, 4)[i] =   Offset_x + Column(dt1, 1)[i];
if( Max_Y1 > Max_Y2,
		Column(dt1, 5)[i] =  Offset_y  - Column(dt1, 2)[i] ;,
		Column(dt1, 5)[i] =   Offset_y + Column(dt1, 2)[i];
"A new column needs to be created that  if the X Coord column's maximum value for wafer 1 is greater than the X Coord column's maximum value for wafer 2, the offset needs to be subtracted from wafer 1's X Coord values.  If that is not true, then the offset is added to the X Coord values.
This step needs to be repeated for the Y Coord."
Jim, would you mind sharing an example code for the above sentence? I was able to Find the Max values for X and Y and the abs difference
Good work getting as far as you did.  I strongly suggest you take the time to read the Scripting Guide.
Below is a modification to your code that populates the new columns
Clear Globals();
Clear Log();
dt1 = Data Table( "Wafer 1" );
dt2 = Data Table( "Wafer 2" );
dt1 << New Column( "New_X", Numeric, "Ordinal", Format( "Best", 12 ) );
dt1 << New Column( "New_Y", Numeric, "Ordinal", Format( "Best", 12 ) );
Max_X1 = Col Maximum( dt1:X Coord );
Max_Y1 = Col Maximum( dt1:Y Coord );
Max_X2 = Col Maximum( dt2:X Coord );
Max_Y2 = Col Maximum( dt2:Y Coord );
Offset_x = Abs( Max_X2 - Max_X1 );
Offset_y = Abs( Max_Y2 - Max_Y1 );
For( i = 1, i <= N Rows( dt1 ), i++,
	If( Max_X1 > Max_X2,
		//dt1:New_X[i] = Offset_x - dt1:XCoord[i],
		//dt1:New_X[i] = Offset_x + dt1:XCoord[i]
dt1:New_X[i] = dt1:XCoord[i] - Offset_x,
dt1:New_X[i] = dt1:XCoord[i] + Offset_x ) ); For( i = 1, i <= N Rows( dt1 ), i++, If( Max_Y1 > Max_Y2, //dt1:New_Y[i] = Offset_y - dt1:YCoord[i], //dt1:New_Y[i] = Offset_y + dt1:YCoord[i]
dt1:New_Y[i] = dt1:YCoord[i] - Offset_y,
dt1:New_Y[i] = dt1:YCoord[i] + Offset_y ) );
Jackie_
@txnelson ,
Thanks, Jim. The code works but the results isn't what I expected. You see the X and Y axis don't align with the wafer 2 Map
I did not notice this before....the issue is you need to subtract or add the Offset from the coordinate, not the coordinate from the offset.
Clear Globals();
Clear Log();
Here is the original version of the code that I undependably came up with.  It runs faster, but gives the same results.  Take a look at the code, and check out the different approach.
xOffset = abs(col max(dt1:X Coord) - col max(dt2:X Coord));
yOffset = abs(col max(dt1:Y Coord) - col max(dt2:Y Coord));
If( Col Max( dt1:X Coord ) > Col Max( dt2:X Coord ),
	dt1 << New Column( "New X Coord", set each value( :X Coord - xOffset ) ),
	dt1 << New Column( "New X Coord", set each value( :X Coord + xOffset ) )
If( Col Max( dt1:Y Coord ) > Col Max( dt2:Y Coord ),
	dt1 << New Column( "New Y Coord", set each value( :Y Coord - yOffset ) ),
	dt1 << New Column( "New Y Coord", set each value( :Y Coord + yOffset ) )
Jackie_
It doesn't work either Jim. See the results below
Your axes have been reversed on one of the charts
