Ypsistub
Aug 17, 2017
Office 2016 install triggered JMP files to open in a separate window
Since installing Office 2016 on my computer, my JMP files have been opening in separate windows unless I open the file from an already open window. I do not like this, how do I get back to only having 1 JMP window (unless I want more than 1)?
Jun 22, 2012
Re: Office 2016 install triggered JMP files to open in a separate window
Go to
     File==>Preferences==>Windows Specific
The click on the "Reset Associations" at the lower middle of the displayed window
Ypsistub
Aug 17, 2017
Thanks Jim, I tried it and it didn't work. I even restarted my computer just in case. I then tried reset to defaults after and that didn't work. Any other recommendations?
Jun 22, 2012
Try this:
Close JMP.
Go to a .jmp file and Rt Click on it
Select "Open With"
Select "Always Use this to open"
Then select the option that allows you to navigate to the jmp.exe file to be used to open the file.
If this does not solve the problem, you need to contact the JMP support staff.
Jeff_Perkinson
Community Manager
Jun 23, 2011
I'm not sure I'm understanding the behavior you're describing. Since JMP 10, every JMP data table will open into it's own window.
Can you clarify exactly what's happening?
  • What are the two (or more) ways that you're opening JMP files that result in different behaviors?
  • Are you opening data tables or reports?
  • Are you getting multiple Home windows with every JMP file that you open?
  • Can you provide screen captures to show what's happening?
-Jeff
Craige_Hales
Mar 21, 2013
and what jmp version(s) are running? help->about, for the different ways you start JMP.
Craige
