BookmarkSubscribe
Odds Ratios in Logistic Regression
I'm a bit confused about the OR function in Nominal Logistic Regression. I have a range of predictor variables, some of which are nominal and some of which are continuous. I understand the output from the regression in terms of the model, parameter estimates and likelihood ratios but I am a bit stumped on the OR output. For my nominal predictors it seems easy enough but the ORs for the continuous variables are quoted as "unit odds ratio" and "range odds ratios" with reciprocal options as well. The numbers quoted for my significant predictors seem very low compared to the ORs for the non-significant.
I'm not sure If I'm doing it correctly or if there is a step I have to do myself. Has anyone used this function enough to be able to comment?
