BookmarkSubscribe
masum111bd
Number of seris
Hi
During stacking, I want to make Number of Series a variable which sould be calculated before. It says, this should be a positive intege. Is there any workaround?
// Stack the data
Data Table( "Sample_data2" ) << Stack(
columns( ColList ),
Source Label Column( "Label" ),
Stacked Data Column( "Data" ),
Number of Series( j/12 ),
Contiguous
Number of series should be a positive integer
Re: Number of seris
You have to evaluate the equasion you are using for the setting of the numer of series
// Stack the data
columns( ColList ),
Number of Series(eval( j/12 ) ),
Contiguous
The resulting value has to be an integer, which means your value of the variable "j" has to be, 12, 24, 36 etc
Re: Number of seris
// Stack the data
columns( ColList ),
Contiguous
