Number Col Box << set conditional format
I see in JMP 9 there's a "conditional format" property of a Number Col Box, however I can't find any documentation on it.  Does anyone have any examples of its use, please?  In particular, I'd like to know if I can embolden, underline and/or change the text color of the contents of cells that fulfil the condition.
Many thanks
pmroz
The help in JMP 10 provides a few more clues:
Set Conditional Format
obj << Set Conditional Format(
Correlation|Pvalue|Factor Pattern )
Sets the conditional format
Example program:
Open( "$SAMPLE_DATA/Time Series/Oil.jmp" );
ts = Time Series( X( :Depth ), Y( :Response ) );
tsr = ts << report;
ncb = tsr[Number Col Box( 5 )];
ncb << Set Conditional Format( "PValue" );
Re: Number Col Box << set conditional format
Excellent - many thanks!  So... it is possible to change the font color on an individual cell basis within a Number Col Box: using the above example as a starting point, I've been playing around with the PValue and Correlation parameters to find out a bit more about them, and produced the following, which shows the color schemes that are used to highlight the significance of a list of P values (red for P<0.05, orange for P<0.01), and a list of correlations from +1 through 0 to -1 on a blue-gray-red scale:
PValueTable = Table Box();
CorrelTable = Table Box();
For( k = 1, k <= 15, k++,
       PValueList = {};
       CorrelList = {};
       For( i = 1, i <= 15, i++,
              Insert Into( PValueList, Random Uniform() / 5 );
              Insert Into( CorrelList, 1 - 2 * ((k - 8) ^ 2 + (i - 8) ^ 2) / 98 );
       PValueTable << append(
              Number Col Box( "Col " || Char( k ),
                     PValueList,
                     set format( 6, 3 ),
                     set width( 12 ),
                     <<Set Conditional Format( "PValue" )
       CorrelTable << append(
                     CorrelList,
                     set format( 6, 3 ),
                     set width( 12 ),
                     <<Set Conditional Format( "Correlation" )
PValueTable << table style( "Embossed" );
CorrelTable << table style( "Embossed" );
nw = New Window( "My Window",
       Lineup Box( N Col( 2 ),
              Text Box( "Lots of P Values:  " ),
              PValueTable,
              Text Box( "Lots of Correlations:  " ),
              CorrelTable
I'm now wondering if (a) the color scheme can be changed, and also (b) whether it's possible to define your own set of rules.  Does anyone know?
In Preferences, under Reports, there is a place to bring up the rule editor.  You can view / modify the existing rules, and also create your own rules.
You can also create a new rule from the Column Numeric Format dialog, shown when you double-click on a numeric column.  You have the option to select a Conditional Highlight scheme or "Add New..."
pmroz
Played around with this a bit.  Here's how to set up a new rule using JSL.  This rule will show values greater than 0 in bold red, and values <= 0 in slightly dimmer text.
preferences(
    Conditional Formatting Rules(
        RuleSet(
            RuleName( "Alert Rule" ),
// Less than or equal to 0, dim the text 80%
            LessThan( Value( 0 ), Inclusive( 0 ), Format( TextAlpha( 0.8 ) ) ),
// Greater than 0, bold red
            GreaterThan(
                Value( 0 ),
                Inclusive( 0 ),
                Format( Text Color( "Dark Red" ), FontStyle( Bold ) )
This code only needs to be run once for a user, btw.
Next, to assign this format to a number col box:
one_colbox << Set Conditional Format("Alert Rule");
