BookmarkSubscribe
m4mazzotti
Notified when data table is done computing
Hello everyone,
I currently have a working data table where 3 columns are constants and 1 column is a formula.
IDABC = Formula (A+B)
1123
1347
2246
On the UI side, that data table is created using a Table box, but only for the selected ID. Rows with IDs different form the selected ID are hidden. A and B are a Number Edit Col Box and C is just a Number Col Box.
When users edit A or B, i want to update C with the new value.
The problem that i am facing is that the time that JMP takes to calculate C varies. If I dont wait enough time to copy the C value, I will just get the "old" value. Is there a way for me to be notified when JMP is done evaluating all the formulas? I want to make sure I just copy the C value when JMP is done calculating.
I am not using Data Table Col Box because I am not showing all the rows and I havent figure out a way to hide rows in the Data Table Col Box. I could create a subset, but things would get messy as users may open many customers during one session.
Thanks,
Byron_JMP
Re: Notified when data table is done computing
try dt<<run formulas;
it keeps the next step from happening until the table is finished updating.
JMP Systems Engineer, Pharm and BioPharm Sciences
Byron_JMP
