David_Burnham
Nonlinear Platform: Missing Model Message
I am using the Nonlinear  Platform to fit kinetic models.  For certain combinations of start points I get a message "N Missing Models".  Does anyone know what that means, and the cause of it.  Obviously at one level the cause is to poor start point, but I would expect that to just result in a failure to converge error message.
whereas with a different start point:
-Dave
Jeff_Perkinson
Re: Nonlinear Platform: Missing Model Message
I've not seen that message before.
It might be best to let Tech Support take a look at this. It will help if you can include an example to reproduce the problem.
-Jeff
-Jeff
