BookmarkSubscribeRSS Feed
bwanders
Nonlinear Graphing
In the "Nonlinear" fit curve graph, how do I change the line color?
KarenC
Re: Nonlinear Graphing
If you right click on the graphic you will bring up a floating menu.  Select "Customize..." from the menu.  In the dialog box that now appears find the curve for which you want to change the color, you will see some JSL, look for  Pen Color( -2994485 ); and change the number to your desired color in " " so Pen Color( "blue"); click the apply button and you should have a new line color.
bwanders
In quotes- that's what I was missing.  Thank you Karen.
lbai6
Community Member
HI, I can't delete the number and can't change the pen color, what's going on ?
Tina
Is there a way to hard code the pen color for a nonlinear fit in a JSL script?
Right click on the line in the legend and pick the desired color.  If you do not have a legend displayed, you can right click on the graph and select Customize.
