BookmarkSubscribe
David_Burnham
Nonlinear Fit SSE Grid
I want to program a grid search prior to a nonlinear fit.
SSE grid gives me what I want, but it doesn't look like it is scriptable? (i.e. I want to automate it fully).
Any ideas?
Dave
-Dave
ms
Super User ms
Re: Nonlinear Fit SSE Grid
Not sure I understand what you want, but if the goal is to use the SSE Grid for improving the initial parameter settings, the approach below may be useful and quite fast.
dt = Open( "$SAMPLE_DATA/Nonlinear Examples/US Population.jmp" );
h = {"Min", "Max", "Number?"}; // colbox headers
m = [12 17 10,
0.005 0.03 10]; // Input ranges for the grid
nl = dt << Nonlinear( Y( :pop ), X( :Name( "X-formula" ) ), SSE grid );
// Specify the grid and make table
grid_ob = Report( nl )[Outline Box( "specify?" )];
For( i = 1, i <= 3, i++,
    grid_ob[Number Col Box( h[i] )] << set values( m[0, i] )
grid_ob[2] << click;
dt_grid = Current Data Table();
//Find min SSE and make matrix of parameters
min_SSE=Loc Min( Column( dt_grid, "SSE" ) << get as matrix);
init_params = Matrix(
    Repeat(
        i = 0;
        {i++ ; Column( dt_grid, i )[min_SSE]};,
        N Row( m )
// Set initial parameters and finish
Report( nl )[Number Col Edit Box( "Current Value" )] << set values( init_params );
nl << finish;
David_Burnham
My question was specifically whether the SSE Grid message could be fully programmed.
I have another way which I think will work:
- set iteration limit to zero
- perform the fit
- extract the SSE value
do all this in a grid search loop.
I think that will work, so I don't need an answer unless someone knows some hidden parameters for the SSE Grid message
-Dave
David_Burnham
The approach I described worked but is much slower than I would like.
So still looking to code up SSE Grid - or figure out how it does it so fast that I can code it up myself
-Dave
ms
Super User ms
m = [12 17 10,
    Repeat(
        i = 0;
        N Row( m )
nl << finish;
David_Burnham
Spot on!  Thanks MS
-Dave
David_Burnham
I will code up the SSE calculation myself without using the platform.  This should be as fast as the SSE Grid unless it is doing something really clever.
Consider this closed.
-Dave
