BookmarkSubscribeRSS Feed
Non linear constraints in Mixture DOE
Hello, I need to add constraints in my Mixture DOE that are not linear. Is it possible ? Typically I would add these constraints : X1/X2<0.5 and X1/X2
thanks a lot,
dp
mpb
Jun 23, 2011
Re: Non linear constraints in Mixture DOE
Can't tell what your second constraint is but the first can be rewritten as
X1 - 0.5*X2 < 0
which is linear. If you have a constraint that cannot be reframed as a linear constraint then you can use the Disallowed Combinations option, but that is not the preferred way to go.
