shhiggins
Newbie scripting - capturing mouse clicks
Hello jmp community,
A real newbie here and hoping for a simple way to execute and script an analysis. From my limited exposure I understand that jmp can capture all of the mouse clicks, but I see no log entries for my actions. The application is to quantify unknowns from a standard curve, so first the calibrators are selected and then the unknowns are hidden/excluded. Can this be recorded and automated in a simple way?
Thanks
Steve Higgins
Re: Newbie scripting - capturing mouse clicks
Have you seen Inverse Prediction in the Fit Curve platform? Just want to be sure you do not waste your time on a script that is not necessary.
