BookmarkSubscribeRSS Feed
razmah
Jul 20, 2015
Newbie question: How can I set variables as values of a column?
I have 5 variables and need to put them in cells of a new column; I wrote the following script but it doesn't work
New Column( "Distance",
Numeric,
Continuous,
Format( "Best", 12 ),
Set Values( [char(Step1_Cond1), char(Step2_Cond1), char(Step3_Cond1),
char(Step4_Cond1), char(Step5_Cond1)] );
stan_koprowski
Community Manager
Aug 8, 2012
Solution
Re: Newbie question: How can I set variables as values of a column?
Hi Rose,
Almost there--
Try the following:
// Create a new table
dt = New Table( "TMP" );
// Add a new column to the table called distance
dt << New Column( "Distance",
  Character,
  Nominal,
  Set Values( {Step1_Cond1, Step2_Cond1, Step3_Cond1, Step4_Cond1, Step5_Cond1} )
Best,
Stan
stan_koprowski
Community Manager
Aug 8, 2012
Solution
Hi Rose,
Almost there--
Try the following:
  Character,
  Nominal,
Best,
Stan
razmah
Jul 20, 2015
Thanks a lottttt
