Bill_McN
Feb 23, 2017
Newbie help with Dialog variable to use within a formulae
Hi I'm trying a basic Delta between 2 columns which I want to choice using a dialog to choose both columns and use a basic delta X-Y formulae. However, I don't seem to be able to work out the correct syntax for this. The formulae is not carrying into the new column which is being created. When I hover over the my_X and my_Y field they do bring up the correct names. Can you advice...
dt_values = Current Data Table();
cdlg = Column Dialog( yCols = ColList( "POR", MinCol( 1 ), MaxCol( 1 ) ) );
my_Y = cdlg["yCols"];
cdlg = Column Dialog( xCols = ColList( "Diff", MinCol( 1 ), MaxCol( 1 ) ) );
my_X = cdlg["xCols"];
dt_values << new column("Delta", Numeric, Format( "Fixed Dec", 10, 2 ), formula( Column(my_X[1]) ) - (Column(my_Y[1])));
Basic Table
ABDelta
13
212
Jun 22, 2012
Solution
Re: Newbie help with Dialog variable to use within a formulae
Here is a solution to your script.
dt_values << New Column( "Delta",
	Numeric,
	formula( eval(my_X[1] )  - eval( my_Y[1] ))
However, a better version of your code is:
cdlg = Column Dialog( yCols = ColList( "POR", MinCol( 1 ), MaxCol( 1 ) ) ,xCols = ColList( "Diff", MinCol( 1 ), MaxCol( 1 ) ) );
Eval(
Substitute(
		Expr(
			dt_values << New Column( "Delta", Numeric, Format( "Fixed Dec", 10, 2 ), formula( _x_ - _y_ ) )
	Expr( _x_ ), Parse( ":" || Char( my_X[1] ) ),
	Expr( _y_ ), Parse( ";" || Char( my_Y[1] ) )
A final comment:  JMP has downgraded the value of the Column Dialog function, and points users to use a "Modal" New Window() function.  You can see illustrations on how to do this in:
     Help==>Books==>Scripting Guide
bill_worley
Jul 2, 2014
Hi Bill,
You can generate a new difference column by highlighting the two columns of interest and then right click in the column header.  Go to the New Formula Column tab and click to follow the prompts.  An example is shown below.
HTH
Bill W.
Bill_McN
Feb 23, 2017
Sorry using JMP 11.1, and that option is not available.
Jun 22, 2012
Solution
	Numeric,
Eval(
Substitute(
		Expr(
Bill_McN
Feb 23, 2017
Thanks for both codes, they both worked.  I've used the 2nd :-)
I'll review the modal as per your recommendation, but curious as to whether the dialog will still work in future as many scripts currently use the dialog functionality at moment.
