BookmarkSubscribeRSS Feed
joickle
Jun 30, 2015
New table on SQL refesh
Is there a way to prevent JMP from opening up a new table everytime I do an SQL update and there is new columns?  I have a stored procedure that refreshes the table, but causes it to create a new file every time there is a new column.  Can I merge them by default in the same table?
briancorcoran
Jun 23, 2011
Re: New table on SQL refesh
JMP 12 will not create a new table IF the new columns are all at the rightmost part of the table, AND all the additional columns are formula columns.  For versions prior to JMP 11, there is really nothing you can do that doesn't require scripting.
Brian Corcoran
JMP Development
joickle
Jun 30, 2015
Thanks for the information.  Is there a way to do this through scripting? and if so would you have an example of the coding to do it?
briancorcoran
Jun 23, 2011
I don't have an example.  A scripting solution would look something like reopening the table without it being visible, and then manually replacing all of the values in the original table with the values from the invisible table.  Not a great solution.
Brian
