qspringleaf
New Create A column to count Cycle Time
Refer to below data table, how to New Create A column to count Cycle Time? kindly help to suggest. thanks a lot.
1.need sort properly by "Group Name" and "Date".
2. within same "Group Name", with "Date" increase, column"Count" number increases, after a certain level (the max value maybe not fixed, sometimes change), it will be back to small value, which means another cycle start.
Group NameDateCount
P14/22/2020 7:261
P14/22/2020 8:262
P14/22/2020 9:263
P14/22/2020 10:264
P14/22/2020 11:265
P14/22/2020 12:266
P14/22/2020 13:267
P14/22/2020 14:268
P14/22/2020 15:269
P14/22/2020 16:2610
P14/22/2020 17:2613
P14/22/2020 18:261
P14/22/2020 19:262
P14/22/2020 20:263
P14/22/2020 21:264
P14/22/2020 22:265
P14/22/2020 23:266
P14/23/2020 0:267
P14/23/2020 1:268
P14/23/2020 2:269
P14/23/2020 3:2610
P14/23/2020 4:2611
P14/23/2020 5:261
P14/23/2020 6:262
P14/23/2020 7:263
P14/23/2020 8:264
P14/23/2020 9:265
P14/23/2020 10:266
P14/23/2020 11:267
P14/23/2020 12:268
P14/23/2020 13:269
P14/23/2020 14:2610
P14/23/2020 15:2618
P24/22/2020 5:261
P24/22/2020 6:262
P24/22/2020 7:263
P24/22/2020 8:264
P24/22/2020 9:265
P24/22/2020 10:266
P24/22/2020 11:267
P24/22/2020 12:268
P24/22/2020 13:269
P24/22/2020 14:2610
P24/22/2020 15:2611
P24/22/2020 16:261
P24/22/2020 17:262
P24/22/2020 18:263
P24/22/2020 19:264
P24/22/2020 20:265
P24/22/2020 21:266
P24/22/2020 22:267
P24/22/2020 23:268
P24/23/2020 0:269
P24/23/2020 1:2610
P24/23/2020 2:2611
P24/23/2020 3:261
P24/23/2020 4:262
P24/23/2020 5:263
P24/23/2020 6:264
P24/23/2020 7:265
P24/23/2020 8:266
P24/23/2020 9:267
P24/23/2020 10:268
P24/23/2020 11:269
P24/23/2020 12:2610
P24/23/2020 13:2611
Re: New Create A column to count Cycle Time
One just needs to check to see if the group changes and then reset myCycle
If(
	Row() == 1, myCycle = 1,
	:Group Name != Lag( :Group Name ), myCycle = 0
If( :Count < Lag( :Count ),
	myCycle
myCycle;
Given your data table you provided, the following formula will work.  I have attached your data table with the formula applied
If( Row() == 1, myCycle = 1 );
	myCycle
myCycle;
qspringleaf
thanks a lot, it works well for one group name, still need your suggestion on multiple group names.
actually this table have one column named "group name", in this column have P1 and P2 2 groups, what I want is "P1/P2 count cycle time separately".
so P2 start to count from "1" instead of "4".
thanks a lot.
If(
	myCycle
myCycle;
qspringleaf
Cool, it works well, thanks so much.
