DavidLeber
Neural Platform Benchmarking: Runtime
All,
I'm attempting to do some benchmarking on the Neural Platform to get an idea of how many nodes/how much boosting my data set typically needs in order to get reasonable results and how much time it takes. Is there any way to determine, after a run is complete, how much time the run took? Currently I'm eyeballing it.
Regards,
David Leber
gzmorgan0
Re: Neural Platform Benchmarking: Runtime
Look at the function Tick Seconds() or HP Time() for high performance time . Here is the example from the JMP Scripting Index for Tick Seconds().
t1 = Tick Seconds();
Open( "$SAMPLE_DATA/Big Class.jmp" );
t2 = Tick Seconds();
Round( t2 - t1, 3 );
 Also if you have a script you can use the debugger. And select Profile JSL Script.
