BookmarkSubscribeRSS Feed
NLMIXED SAS procedure in JMP
I found NLMIXED is a very useful procedure, especially regarding estimation of confident limit for model parameter or any expression of parameter. Is this procedure fully implemented in JMP? I'm not sure that the way JMP compute non linear model is the same. Parameters standard error and confident limits may differ.
