moorea
Multivariate: MDS help
Hi all, I am trying to recreate an analysis I found as part of a research project. The author states that the performed an non-metric multidimensional scaling with Sorensen distance. The data is life history characteristics (max size, max age, age at maturity, larval size, and fecundity) for bivalves. Using their data I calculated the sorensen dissimilarity matrix in R using the distance function, then analyzed that matrix using the Multidimensional scaling option in JMP Pro 14.  The result I get is this weird circle that I have attached. I also get it when I run my own similar, but larger, dataset. I've also tried running the MDS in R where I get a similar circle/curve. Does anyone know what could be leading to this? The stress seem quite low to me at 0.1 but I don't know if that is unusual.
I'm new to multivariate analysis so any feedback you have to offer would be helpful.
phil_kay
Re: Multivariate: MDS help
It sounds like your challenge is in understanding the Sorensen distance matrix that you created using R. The JMP Community is probably not the best place for advice on this.
Regards,
Phil
moorea
It was an issue with data transformation. Thanks for the reply
