BookmarkSubscribeRSS Feed
malte
Community Trekker
Mar 30, 2015
Multiple repetition of tests in a custom design.
Hello JMP-Community,
I want to create a custom design of experiments. I would like to repeat every set of parameters for example 5 times. How do I create a table with 5 repititions per set of parameters.
Thanks for help!
Malte
louv
Jun 23, 2011
Re: Multiple repetition of tests in a custom design.
Malte,
Like everything in JMP there may be more than one way to accomplish your goal. You did not specify which JMP version you are using because it has changed somewhat in more recent versions. You can set up your experiment and in the user specified increase the number of runs to equal the number of runs that would equal the number of replicates that you desire. So for example a 4 continuous factor example generated a 16 run default and in the user specified field I entered 16X5 = 80 and obtained 5 replicates of each setting. Alternatively you could generate the 16 runs and then clone those 16 runs 4 additional times and randomize with and additional column using the column formula= random function.
I hope this helps.
malte
Community Trekker
Mar 30, 2015
Thank you, The copy-paste/clone solution works fine.
