adam
Multiple input for Graph Builder
Hi All,
I am working on a script that will allow me to select more than one Y response(and X factor as well)  and using Graph builder, I will be able to plot it accordingly. I am able to select the relevant Y and X but somehow the Graph builder part is not working. Here is the script:
dlg = Column Dialog(
	ColID = Col List( "X, Factor", Max Col( 1 ) ),
         SS  = Col List( "Y, Response" ),
); Graph Builder( Variables( X( Column(dt,ColID ), Y( Column(dt, SS ) ), Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ) )), );
Please let me know which part of the script went wrong.
Thank you.
Re: Multiple input for Graph Builder
The values returned from the Column Dialog are not in a scaler format.  They are returned in a list.  In your example, the list is named dlg.
Look in the JMP Scripting Guide for details
     Help==>Books==>Scripting Guide
ms
Super User ms
Jim is right. For the assignments of ColID and SS to be effective, the list dlg must be evaluated first. Also, there seems to some misplaced parantheses in the code.
Try this:
    ColID = Col List("X, Factor", Max Col(1)),
    SS = Col List("Y, Response", Max Col(1))
Eval List(dlg[1 :: 2]);
Graph Builder(
    Variables(X(Column(dt, ColID)), Y(Column(dt, SS))),
    Elements(Points(X, Y, Legend(3)), Smoother(X, Y, Legend(4)))
ms
Super User ms
Try this:
Graph Builder(
adam
Thank you Jim and MS.
