yfcgreen
Multiple formula edit in JMP
Hello All,
Has anyone has the experience to multiple edit the formulas in columns?
For example, a set of formulas were pasted to a new set of columns of a new data table using "Paste Column Properties". There was a column name from the original data table column, which didn't exist in the new dataset. So all the formulas needs to be suppressed one by one. In order to make them work, it seems that I need to open these columns formulas one by one to correct the old column name. Is there anyway to make this faster?
Thanks!
Re: Multiple formula edit in JMP
A script could do that quickly.
