BookmarkSubscribe
celestine
Community Trekker
Multidimension List Possible?
Hi, i was wondering, how do i declare/use a multidimensional list in the following scenario:
For( i = 1, i <=N Items( var_list_max ), i++,
               max_val={}; //initialize array
               max_name={};//initialize array
                              for(j=1,j<(col_listitems+1),j++,
                              //show name
                              max_name=x[text box(j+13)]<<get text;
                              show(max_name);
                              //show values
                              max_val=x[numberedit box(j)]<<get text;
                              show(max_val);
i would like to use the bigger loop's variable ("i") as a subscript along with the smaller loop's variable ("j"). eg: max_val so that i can recall the value when i need it, else the code above keeps overwriting the values in the lists, max_name and max_val according to the number of col_listitems (eg 5 items and hence keep writing and overwrite every five times). Any ideas? thanks in advance!:D
ms
Super User ms
Maybe a list of lists (of lists...) is what you need?
A={1,2};
B={3,4};
C={A,B};
show(C[1][2]);
ms
Super User ms
A={1,2};
B={3,4};
C={A,B};
show(C[1][2]);
celestine
Community Trekker
Thanks so much for the help MS, appreciate it!:)
