farnaz
Multi panel box plot graph
I would like to create a "multi panel" graph (I believe that is the correct terminology for it). I am trying to overlap 3 box plots from different variables on one graph. I am not sure if this is possible on JMP?! Thank you!
XanGregg
Re: Multi panel box plot graph
I can imagine different interpretations from that description. Below is one possibility which is the result of putting 3 variables in the Y role in Graph Builder and choosing the Box Plot element.
