Moving average calculation in JMP 6
Hi There,
Is there a way for me to calculate the moving average in JMP 6?
Thanks,
Re: Moving average calculation in JMP 6
I think you can do it using the statistical "summation" function and row functions. Here's an example for a 4-point moving average:
If(Row() < 4, Empty(), Summation(i = Row() - 3, Row(), :Column 1[i,Empty()]) / 4)
I used the "If" function to avoid errors when ( Row()-3 ) is less than 1. I'd be interested to see if someone else has a simpler way to do this.
GoodMan
Community Trekker
Hi BillHallet,
I wonder if i should have a table with 1 column more that 4 row. Then run this JSL to get 4-point moving average? Then the result will be added into the following row?
Thanks a lot,Kun
