BookmarkSubscribeRSS Feed
msharp
MouseBox problem "<< SetDropTrack"
MouseBoxes are hard.  I'm trying to implement a drag and drop solution to move pictures around.
Below I've taken the example code from Scripting Index >> Mouse Box >> SetDropTrack and have re-implemented it to contain images in the boxes instead of letters.  Except I can't get the images to populate in the new location after dropping.  Any help would be appreciated.
//Datatable with :LocalPath Column that contains paths to image files on computer
dtFull = current data table();
path1 = dtFull:LocalPath[20];
path2 = dtFull:LocalPath[21];
path3 = dtFull:LocalPath[22];
path4 = dtFull:LocalPath[23];
path5 = dtFull:LocalPath[20];
path6 = dtFull:LocalPath[21];
path7 = dtFull:LocalPath[22];
path8 = dtFull:LocalPath[23];
img = NewImage(path1);
img2 = NewImage(path2);
img3 = NewImage(path3);
img4 = NewImage(path4);
img5 = NewImage(path1);
img6 = NewImage(path2);
img7 = NewImage(path3);
img8 = NewImage(path4);
//Below Modified Scripting Index >> SetDropTrack example
nextToBlank = Function( {x, y}, /* helper function */
       If( /* child is border, grandchild is text */
              (x > 1 & isempty(((puzzle[x - 1][y] << child) << child) << getimage)) | (x < 3 & isempty(((puzzle[x + 1][y] << child) << child) << getimage))
               | (y > 1 & isempty(((puzzle[x][y - 1] << child) << child) << getimage)) | (y < 3 & isempty(((puzzle[x][y + 1] << child) << child) << getimage))
              1,
              0
);/* only allow drag begin if next door to empty cell */
dragBegin = Function( {this, clickPt},
       {x, y} = this << getUserData;
       Print("dragBegin");
       If( nextToBlank( x, y ),
              image = ((this << child) << child) << getImage/* the message is the textbox content */
       , /* else */
              0 /* suppress the drag */
);/* function to remove the character from the source cell, but only if the drop was successful */
dragEnd = Function( {this, clickPt, how}, /* how is copy/move/ignore */
       destbox = this << getDestBox;
       If( Is Empty( destBox ),
              Show( "unknown destination" );
              0 /* don't know where the dest was, force ignore */
              Try(
                     {x, y} = destbox << GetUserData,
                     x = -1;
                     y = -1;
              ); /* the destbox might not have a list in userdata */
              If(
                     Try(
                           puzzle[x][y] != destbox,
                           1 /*throw is same as !=*/
              , /* x,y might not be valid index */
                     Show( "not dropped in this puzzle" );
                     0 /* not this puzzle instance, force ignore */
              , /* else */
                     If( how == "ignore",
                           Show( "drop not completed" );
                           0 /* the drop was not completed */
                     , /* else */
                           ((this << child) << child) << setImage( " " )
       0 /* the return code is ignored */
);/* function to decide if a drop is allowed.  return codes (0,1) are critical. */
dropTrack = Function( {this, clickPt},
       sourcebox = this << getSourceBox;
       If( Is Empty( sourcebox ),
              Show( "unknown source" );
              0 /* no drop from unknown source box */
       , /* else */
              Try(
                     {x, y} = sourcebox << getUserData,
                     x = -1;
                     y = -1;
              ); /* the sourcebox mightnot have a list in userdata */
              If(
                     Try(
                           puzzle[x][y] != sourcebox,
                     Show( "not from this puzzle" );
                     0 /* not sourced from this puzzle instance, ignore */
              , /* else */
                     If( !isempty(((this << child) << child) << getImage),
                           0 /* no drop on occupied cell */
                     , /* else */
                           1 /* allow drop on the blank cell */
);/* function to implement the drop */
dropCommit = Function( {this, clickPt, image},
       ((this << child) << child) << setImage( image );
       1; /* ignored */
);/* cursor changer for cells that can source a drag */
track = Function( {this, clickPt},
              this << setCursor( "Hand" ),
              this << setCursor( "Arrow" )
       1; /* ignored */
);/* helper function to construct the displaybox tree */
mb = Function( {letter, x, y},
       MouseBox(
              Border Box( Left( 9 ), Right( 9 ), top( 3 ), bottom( 3 ), sides( 15 ),
                     Picture Box( letter )
              <<setUserData( Eval List( {x, y} ) ), /* remember my location.  I don't move, but my content changes. */
              <<setDragEnable( 1 ),
              <<setDragBegin( dragBegin ), /* dragFunctions defined below */
              <<setDragEnd( dragEnd ),
              <<setDropEnable( 1 ),
              <<setDropTrack( dropTrack ),
              <<setDropCommit( dropCommit ),
              <<setTrackEnable( 1 ),
              <<setTrack( track )
puzzle = Eval List(
       {Eval List( {mb( img , 1, 1 ), mb( img2, 1, 2 ), mb( " ", 1, 3 )} ),
       Eval List( {mb( img3, 2, 1 ), mb( img4, 2, 2 ), mb( img5, 2, 3 )} ),
       Eval List( {mb( img6, 3, 1 ), mb( img7, 3, 2 ), mb( img8, 3, 3 )} )}
New Window( "puzzle",
       Border Box( Left( 5 ), Right( 5 ), top( 5 ), bottom( 5 ), sides( 15 ),
              Lineup Box( N Col( 3 ), spacing( 3, 3 ),
                     puzzle[1][1],
                     puzzle[1][2],
                     puzzle[1][3],
                     puzzle[2][1],
                     puzzle[2][2],
                     puzzle[2][3],
                     puzzle[3][1],
                     puzzle[3][2],
                     puzzle[3][3],
Craige_Hales
Staff (Retired)
Re: MouseBox problem "<< SetDropTrack"
So close! the clipboard is only set up to move text, not other JMP objects.  You can convert the picture to a large chunk of text and move that through the clipboard.  (You could also build a different mechanism, perhaps with an associative array to hold the images, using a character key to the associative array.  It would look more complicated but be less stressful on the clipboard/CPU.  If you drag out of the puzzle, into another editor, you'll see the huge chunk of text.)
the character conversion makes your code begin to work:
    image = char(((this << child) << child) << getImage);/* the message is the textbox content */
    image;
and
    image=parse(image);
    ((this<<child)<<child)<<setimage(image);
Craige
msharp
I'm a little surprised no one has responded in a couple days.  I think this problem is kind of fun.  I decided to attach a script with pictures to help others troubleshoot easier.  I've also added notes to better indicate the part of the code I'm having issues with.
Craige_Hales
Staff (Retired)
    image;
and
    image=parse(image);
Craige
msharp
Re: MouseBox problem "&lt;&lt; SetDropTrack"
Thanks for the info.  Seeing your code and explanation I came up with a third solution.  I decided to store the image into a unique namespace (aka. image:image) which I can pass between the functions.
Craige@JMP​ did you see my other post? MouseBox Selecting Multiple Images I also want to be able to select multiple images at one time.  I feel the mousebox can be tricky and the documentation isn't great so I'd appreciate anything info you can provide.
Craige_Hales
Staff (Retired)
Example posted.
Craige
