vince_faller
Mouse box inside graph box
Is there a way to put a mouse box inside a graph box? Specifically around stuff like rect(). I'm making shapes that I want to give tool tips and click functionality.
Vince Faller - Predictum
Craige_Hales
Staff (Retired)
Re: Mouse box inside graph box
No, graphs do not use any display box children that might get attached to them. You can put the mousebox around the graph. You'll get to write similar JSL to support the clicks in the mousebox or using the MouseTrap mechanism Jim pointed out. In either case you get a coordinate and have to decide what item was clicked. There is a point-in-polygon function if you have shapes that are not round or square.
Craige
Are either of these examples from the Scripting Index, what you are looking for?
New Window( "Example",
	exx = 20,
	exy = 50;
	Graph Box(
		Frame Size( 200, 200 ),
		Mousetrap(
			exx = x;
			exy = y;
		Circle(
			{0, 0},
			Sqrt( exx * exx + exy * exy )
	exx = 20,
	exy = 50;
	Graph Box(
		Mousetrap(
			exx = x;
			exy = y;
		Circle(
			{0, 0},
Craige_Hales
Staff (Retired)
Craige
