Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
shivkr
Motion-enabled bar or line chart in JMP
How can we make motion-enabled dynamic bar or line chart in JMP ?
pmroz
Re: Motion-enabled bar or line chart in JMP
Can you be more specific about what you want?  I don't understand what a "motion-enabled dynamic bar or line chart" is.
Regards,
Peter
shivkr
I mean can we create bar graph something similar to motion-enabled bubble chart, which changes dynamically over time?
pmroz
You can open a Data Filter window and turn on animation for a motion effect.  For example:
Run Graph Builder on Big Class.  Plot Height and Weight on the Y axis, Sex on the X axis.  Right click inside the graph and select Points > Change to > Bar.  In the Big Class dataset, select Rows > Data Filter.  Click on Age and then Add.  Uncheck the data filter checkbox for Select, and check the box for Include.  Click on the little red triangle next to the words Data Filter and select Animation.  Click the Play button to see the bar graph change with age.
shivkr
Thanks PMroz
shivkr
Hi, Is there any way in JMP to stop looping of Animation cycle automatically?
Article Labels
