tom_abramov
Level V
Modify data table with Query() function
I'm working with Query() function for quick selections on big JMP tables.
I can't run the "update" command.
Is it possible?
I would like to do something like this:
Query( Table( dt, "t1" ), "UPDATE t1 SET Height = -1 Where Age = 12" );
Thanks.
Re: Modify data table with Query() function
I am not a Query function expert, however the error returned when running your code seems to indicate that a Query can not update a table
Query failed: table t1 may not be modified{5} in access or evaluation of 'Query' , Query/*###*/(Table( dt, "t1" ), "UPDATE t1 SET Height = -1 Where Age = 12")
A simple way to do what you want in regular JSL would be
dt:Height[dt<<get rows where(:age==12)]=-1;
tom_abramov
Level V
Thanks, Jim
With "select", Query() performs much faster than "get rows where".
I was wondering whether "update" will work as well.
An update would work just fine
dt2 = New Table( "My Update", private,
	New Column( "Age", values( [12] ) ),
	New Column( "Height", values( [-1] ) )
dt = dt << Update(
	With( dt2 ),
	Match Columns( :age = :Age )
close(dt2, nosave);
