MathStatChem
Modal Window, cannot pass Set Tip message to button box
When I create a modal window that contains a button box, if i then pass the Set Tip() message to the button box, it doesn't seem to work, the tool tip doesn't appear when I move the mouse over the button box.
_nw=new window("modal window",
	<<Modal,
	_bb=button box("Test")
_bb << Set Tip("Test this");
However, if I remove the <<Modal message in the New Window function, then the Set Tip() works and I can see the tool tip.
Is there a reason for this?  Anyway around this?
Re: Modal Window, cannot pass Set Tip message to button box
A modal window stops all processing except for what is contained within the window.  Therefore the script below is how you have to handle the processing you want
	<<Modal,
	_bb=button box("Test"),
	<<Modal,
MathStatChem
Ok, that works.  I've never tried to do that inside the New Window() function.
I think I understand how <<Modal works better now.  Thanks!
Another variant (not right or wrong, just a different form) is to place the message send in line with the Button Box() arguments:
	<<Modal,
	button box("Test", << Set Tip("Test this"))
