Hi all,
I wrote a function which checks if a value passes or not. If it has, it says in the column beside the value Pass or Fail. For some reason, there a few cells that are blank that should say Fail, but are blank. There are cells that failed and also say fail beside it, so I am little confused trying to debug this one. I also added a screen shot to illustrate what I mean.
oneULPass = Function( {UL, value, test, row},
//UL --> upper limite
//value --> value measured
//test --> which test is this?
//row --> row (device number) in data table
colName1 = test || " Pass";
If( value <= UL,
dtSummary:colName1[row] = "Pass";
pass = 1;
dtSummary:colName1 = "Fail";
pass = 0;
Show(value);
Return( Num( pass ) );
Ah, found it! In the "Fail" part of the If statement, I wrote dtSummary:colName1 = "Fail"; and not dtSummary:colName1[row] = "Fail".
Why would that work for some rows and not for others?
