Martin
Missing bar at bottom of windows
This is probably really easy to fix, but I am missing the bar at the bottom of all windows. See the posted pic. I am using 15.1.0.
the bar is still there in my 14.3.0 version like this,
Any help would is appreciated.
Re: Missing bar at bottom of windows
Hi @Martin,
Try this. Go to the View menu and check the Status Bar option. If it is checked on, it should show up. If not, click on it to enable it.
Did that work for you?
Chris Kirchberg
Principal Systems Engineer, Life Sciences - JMP Global Technical Enablement
SAS Institute, Inc. - Denver, CO
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail: chris.kirchberg@jmp.com
JMP – A Division of SAS Institute | www.jmp.com
Hi @Martin,
Chris Kirchberg
Martin
Yes it did! Thank you @Chris.
