jtmannes
Misaligned Control Limits/Points due to phases
I am creating a control chart with three different phases and my control chart points are not lining up with the limits (sample = denominator). It appears the points are sitting on the middle of the limits instead of the middle. I have looked through all the axis options and cannot find a solution. Also, the issue is only occurring in the first phase of my chart (the "2" phase). I removed the phases and it worked just fine. Any help would be great. My JMP script is below.
Control Chart(
Sample Label( :Clinic Name ),
Phase( :Name( "Results Reported?" ) ),
Sample Size( :Denominator ),
KSigma( 3 ),
Chart Col(
:Rate %,
P( Phase Level( "2" ), Phase Level( "1" ), Phase Level( "0" ) )
Where( :Metric == "Adolescent Immunization Status" ),
Dispatch(
"Control Chart Metric=Adolescent Immunization Status",
OutlineBox,
{Set Title( "Adolescent Immunization Status" )}
Dispatch(
{"P of Rate %"},
"2",
ScaleBox,
{Format( "Percent", 12, 0 )}
Dispatch(
{"P of Rate %"},
"1",
ScaleBox,
{Format( "Best", 15 ), Min( 0.5 ), Max( 22.5 ), Inc( 1 ),
Minor Ticks( 1 )}
Dispatch(
{"P of Rate %"},
AxisBox,
{Add Axis Label( "Rate %" )}
Dispatch(
{"P of Rate %"},
"Proportion for Rate %",
TextEditBox,
{Set Text( "Rate %" )}
Dispatch(
{"P of Rate %"},
"Attributes Chart",
FrameBox,
{Frame Size( 527, 320 )}
Dispatch(
{"P of Rate %"},
"Attributes Chart",
FrameBox( 2 ),
Thanks,
Josh
Re: Misaligned Control Limits/Points due to phases
It is difficult to understand what you are saying from the text.  Can you possibly include a screenshot of the output?
