senatorx
Minimize all Fit data prior to saving graph
Hi, I'm making a bivariate plot with several spline fits.  I want to save only the graph portion to an image file, but not the fit data at the end.  Is there a way to minimize all the fits, or have them populate to a separate window?  When I minimize all the fits then view the script, it creates multiple instances of   Dispatch( {}, "Smoothing Spline Fit", OutlineBox, {Close( 1 )} ), however when re-running the script, it only minimizes the first fit.
Trend = Bivariate(
Y( :Ycol ),
X( :Xcol ),
Fit Where(
  :colName == "fit1",
  Fit Spline( 0.1, Standardized, {Line Color( {213, 72, 87} )} )
Fit Where(
  :colName == "fit2",
  Fit Spline( 0.1, Standardized, {Line Color( {57, 177, 67} )} )
Fit Where(
  :colName == "fit3",
  Fit Spline( 0.1, Standardized, {Line Color( {64, 111, 223} )} )
Fit Where(
  :colName == "fit4",
  Fit Spline( 0.1, Standardized, {Line Color( {207, 121, 38} )} )
Fit Where(
  :colName == "fit5",
  Fit Spline( 0.1, Standardized, {Line Color( {33, 189, 145} )} )
  Dispatch( {}, "1", ScaleBox, {Rotated Labels( 1 )} ),
  Dispatch(
   "Bivar Plot",
   FrameBox,
   {Frame Size( 400, 300 ), Row Legend(
    colName,
    Color( 1 ),
    Color Theme( "JMP Default" ),
    Marker( 1 ),
    Marker Theme( "Standard" ),
    Continuous Scale( 0 ),
    Reverse Scale( 0 ),
    Excluded Rows( 0 )
Trend << Save Picture("\\path\file.png", png) ;
ms
Super User ms
Re: Minimize all Fit data prior to saving graph
There is, at least in JMP 10, a convenient message for outline boxes: << close all like this
splines = dt << Bivariate(
  Y( :weight ),
  X( :height ),
  by( :sex ),
  Fit Spline( 340, Standardized, {Line Color( {208, 64, 86} )} )
Report( splines[1] )["Smoothing Spline Fit"] << close all like this;
senatorx
Ok.  I'm running JMP9.  Any chance there is a more tedious way to accomplish that with JMP9?  I'm guessing there should be some way to give each spline a name or a label that can be individually referenced for closing / minimizing.
thanks.
ms
Super User ms
The command appears to be supported in JMP 9, but JMP 9 seems to be more picky when it comes to adress display boxes by a string. But using a wildcard (?) seems to work in this case.
Report( splines[1] )["Smoothing Spline Fit?"] << close all like this;
senatorx
I never got this to work correctly, but I found that I could just do automated formatting on the images afterwards with a powerpoint macro.
