Dennisbur
Match case ( 0 )
Hello
I would like to find test names that continue "pcie0" sometimes in lower or upper format
I understand I should use Match case ( 0 )
I have added it to my script but received error
can you check what I should change in my script?
Column(dt, "PARAMETR") << Set Each Value( If( Contains(( :TEST_NAME,"pcie0")), Match case( 0 ),"PCIE0",:PARAMETR));
Re: Match case ( 0 )
I'm not sure where Match Case is used outside of Filter Col Selector. You could convert your :TEST_NAME to upper or lowercase using Lowercase() or Uppercase()
Contains(Lowercase(:TEST_NAME), "pcie0")
Dennisbur
OK, thank you
there are any options to use like a mix for upper or lowercase because I have a mix format text in this column?
I'm not 100% sure what you are trying to do here. You can do the comparison with Regex if you cannot use lowercase()/uppercase() or use two conditions
hogi
Level XIII
Column(dt, "PARAMETR") << Set Each Value( If( Contains( :TEST_NAME,"pcie0", Match case( 0 )),"PCIE0",:PARAMETR));
no:
