triunk
Mapping with JMP
Dear JMPers!
Thank  you for this amazing help community
I have a tricky question to all of you:
I would greatly appreciate if you could enlighten me if I can make a map of a region such us Upper Valley of New Hampshire (please attached following ) using our beloved JMP software.
Can I make this map using JMP graphs?
Can I add school districts on this map?
Can I add natural centers on this map?
If yes which data should I have to make this happen (zips, latitude, longitude) how I can limit the map to a region instead of seeing the whole US?
Are there any videos that will help me make this happen!
Any help is MOST WELOMED and VERY MUCH appreciated
THANK YOU SO MUCH for your GREAT SUPPORT and COOPERATION in advance
Best Regards to all
Christos
todds
Re: Mapping with JMP
I came across an interesting JMP add-in called Custom Map Creator.  It looks like it could help you create such a map.  Just go to JMP.com and search for JMP add-ins.
Jeff_Perkinson
Hi Christos,
You can probably create the map you're looking for and the Custom Map Creator add-in is a good start.
I'd also recommend reading this paper for an explanation of the kinds of maps you can create with JMP.
-Jeff
-Jeff
