BookmarkSubscribeRSS Feed
itssteven989
Community Member
Nov 18, 2014
Map of Minnesota
I am trying to make a map of the counties in Minnesota but it is not coming up when I follow the examples.
I am also looking at this http://support.sas.com/resources/papers/proceedings11/289-2011.pdf and still nothing. I have a table with all the counties listed but when I put it in the map shape zone nothing comes up.
I was just wondering if anyone had the files for US counties that I could check mine or any other advice.
Thanks!
stan_koprowski
Community Manager
Aug 8, 2012
Re: Map of Minnesota
I will guide you through the process of adding the US counties by using the JMP sample data file seasonal flu and graph builder.
I added State to the Map Shape zone on the bottom left. Graph Builder then created a map of the US states.
I then added a background map of the US counties by right-clicking on the map and selecting add background map from the Graph menu option.
This allowed me to select US counties to be used as my background map.
I added a local data filter to display the flu results for a particular state of my choosing by clicking on the red triangle and scrolling to the bottom and selecting Script and then Local Data Filter.
I was then able to filter the data on the state of Minnesota.
I hope this helps.
Best,
Stan
Jeff_Perkinson
Community Manager
Jun 23, 2011
To get the map shape role to work your county names must match these values exactly, including the ", MN":
Aitkin County, MN
Anoka County, MN
Becker County, MN
Beltrami County, MN
Benton County, MN
Big Stone County, MN
Blue Earth County, MN
Brown County, MN
Carlton County, MN
Carver County, MN
Cass County, MN
Chippewa County, MN
Chisago County, MN
Clay County, MN
Clearwater County, MN
Cook County, MN
Cottonwood County, MN
Crow Wing County, MN
Dakota County, MN
Dodge County, MN
Douglas County, MN
Faribault County, MN
Fillmore County, MN
Freeborn County, MN
Goodhue County, MN
Grant County, MN
Hennepin County, MN
Houston County, MN
Hubbard County, MN
Isanti County, MN
Itasca County, MN
Jackson County, MN
Kanabec County, MN
Kandiyohi County, MN
Kittson County, MN
Koochiching County, MN
Lac qui Parle County, MN
Lake County, MN
Lake of the Woods County, MN
Le Sueur County, MN
Lincoln County, MN
Lyon County, MN
McLeod County, MN
Mahnomen County, MN
Marshall County, MN
Martin County, MN
Meeker County, MN
Mille Lacs County, MN
Morrison County, MN
Mower County, MN
Murray County, MN
Nicollet County, MN
Nobles County, MN
Norman County, MN
Olmsted County, MN
Otter Tail County, MN
Pennington County, MN
Pine County, MN
Pipestone County, MN
Polk County, MN
Pope County, MN
Ramsey County, MN
Red Lake County, MN
Redwood County, MN
Renville County, MN
Rice County, MN
Rock County, MN
Roseau County, MN
St. Louis County, MN
Scott County, MN
Sherburne County, MN
Sibley County, MN
Stearns County, MN
Steele County, MN
Stevens County, MN
Swift County, MN
Todd County, MN
Traverse County, MN
Wabasha County, MN
Wadena County, MN
Waseca County, MN
Washington County, MN
Watonwan County, MN
Wilkin County, MN
Winona County, MN
Wright County, MN
Yellow Medicine County, MN
-Jeff
