laumeister
Manipulating column cells
Hello JMP community,
Have a series of columns with integers, ranging from 0-100. The column always starts with a 0, and then starts to increase from a certain row number. How can I delete the rows with all 0s, then upshift the non-zero cells? Also I need to apply that for all column on the same sheet.
Example ( '.' means empty cell) initial data:
            Col-1    Col-2   Col-3
Row-1   0              0           0
Row-2   0              0           0
Row-3   0              0           0
Row-4   1              0           1
Row-5   3              1           2
Row-6   8              4           7
End result after manipulation:
            Col-1    Col-2   Col-3
Row-1   1              1           1
Row-2   3              4           2
Row-3   8              .           7
Row-4    .              .           .
Row-5   .              .           .
Row-6   .              .           .
Thanks a lot!
Steve
Re: Manipulating column cells
Here is a sample script that moves the values up for each independent column.  The example data used is the data you provided
dt = New Table( "Example",
	Add Rows( 6 ),
	New Column( "Col 1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Selected,
		Set Values( [0, 0, 0, 1, 2, 3] )
	New Column( "Col 2",
		Numeric,
		"Continuous",
		Set Selected,
		Set Values( [0, 0, 0, 0, 1, 4] )
	New Column( "Col 3",
		Numeric,
		"Continuous",
		Set Selected,
		Set Values( [0, 0, 0, 1, 2, 7] )
	Set Row States( [1, 1, 1, 1, 1, 1] )
colNames = dt << get column names( numeric, string );
For( i = 1, i <= N Items( colNames ), i++,
	theMatrix = Column( colNames[i] ) << get values;
	Column( colNames[i] )[Index( 1, N Rows( dt ) )] = .;
	Column( colNames[i] ) << set values( theMatrix[Loc( theMatrix )] );
