gandi2223
Oct 1, 2014
Make two datasets match by shifting one along x-axis
I have two datasets, each of which consists of a number of (x,y) pairs. Both have a similar shape when y is plotted vs x, but they are shifted along the x-axis with respect to each other. I would like to find the offset in x required to make the two datasets overlap (see attached images).
Is there an elegant way to do this in JMP? I could write a loop that shifts one dataset by small increments and calculate the xi^2 between the two for each iteration to find which offset gives the best match, but I was wondering if there was a smarter way of doing it.
ian_jmp
Jun 23, 2011
Re: Make two datasets match by shifting one along x-axis
I don't think you have overlooked anything that's built in.
Useful prescriptions probably depend on what you can and can't assume about the data, and what figure of merit to use:
  • Would you expect each sample to have the same number of (x, y) pairs?
  • Is it possible that one or more x or y value is missing?
  • How would you wish to quantify 'degree of overlap'?
gandi2223
Oct 1, 2014
Ian,
  • Not necessarily
  • Yes
  • I was thinking of starting with the smaller dataset (i.e. fewer x/y pairs) and calculating the squared difference between each of its datapoints and the (interpolated) y value of the 2nd dataset at the same x value. The x offset between the two datasets where this value becomes a minimum should correspond to best overlap. It shouldn't be too hard to script this, but before doing so, I thought I'd ask if JMP has a built-in function to achieve this goal.
Thanks,
Marcus
