mpg
mpg
Make a combined table from the Distribution Platform
I am trying to make a combined table from the distriibution platform  I am using the foillowing script.
ex: using Big Class.
dist = Distribution(
Stack( 1 ),
Continuous Distribution(
Column( :weight ),
Horizontal Layout( 1 ),
Vertical( 0 ),
Set Quantile Increment( 0.01 )
By( :sex )
dr = dist << report;
tb = dr[TableBox( 1 )];
tb << Make Combined Data Table;
I receive an error in the line tb = dr[TableBox( 1 )];
Using the tree structure, looks like it could be ListBox(8); IfBox(8), OutlineBox(3) or Table Box(1).
I get the same error in all cases.
What am I doing wrong?
Thanks in advance!!
Very Sincerely,
Matt
Re: Make a combined table from the Distribution Platform
Hi Matt,
Try putting a [1] between dr and [Table Box(1)].
If you run just
dr = dist<<report;
and look at the log, you'll notice that dr is a list of DisplayBoxes, so you have to index into that list before you can index into one of the display boxes.
Best,
Michael
Michael Crotty
Sr Statistical Writer
JMP Development
julian
Hi Matt,
I think I see what's happening here. To extract the specific component of the report, you need to include the entire display structure in the JSL call. I modified your code (included below) to pull out the combined report first for the quantiles, then for the summary statistics (I wasn't sure which you were after). Notice that we need to reference the entire tree so JMP knows which box you're referring to.  I hope this helps!
julian
Stack( 1 ),
Column( :weight ),
Vertical( 0 ),
By( :sex )
reportQuantile = Report( dist[1] )[Outline Box (1)][Table Box(1)] << Make Combined Data Table;
reportSummary = Report( dist[1] )[Outline Box (1)][Table Box(2)] << Make Combined Data Table;
mpg
mpg
Thanks Julian,
I see a lot more with the way you laid it out.
Very Sincerely,
Matt Goodlaw
Hi Matt,
If you run just
dr = dist<<report;
Best,
Michael
Michael Crotty
JMP Development
julian
That's a much simpler solution
julian
mpg
mpg
Thanks Michael.  Worked like a charm!
Very Sincerely,
Matt Goodlaw
JMP Sample Note 46983 also addresses this question.  You can find other sample notes by clicking on the Sample Notes link in the Knowledge Base.
Wendy
Article Labels
