BookmarkSubscribeRSS Feed
senatorx
Community Trekker
Make Bivariate Invisible for Performance
I've found that I can boost performance by hiding data tables and subsets like so:
Main_dt = Open(Main_Source, Invisible);
Subset_dt = Current Data Table() << Subset(Selection(), invisible);
However, I can't figure out how to hide the display of a Bivariate plot.  I am using the function below.  How would I modify this to prevent display on screen? (JMP9)
Trend_biv = Function( {xval, yval, P_legend},
      {Default Local},
      ::T_biv = Bivariate(
            Y( Column( yval ) ),
            X( Column( xval ) ),
                  Dispatch( {}, "1", ScaleBox, {Rotated Labels( 1 )} ),
                  Dispatch(
                        "Bivar Plot",
                        FrameBox,
                        {Frame Size( 400, 300 ), Marker Size( 4 ), Row Legend(
                              Column( P_legend ),
                              Color( 1 ),
                              Color Theme( "JMP Default" ),
                              Marker( 1 ),
                              Marker Theme( "Standard" ),
                              Continuous Scale( 0 ),
                              Reverse Scale( 0 ),
                              Excluded Rows( 0 )
I call the function like so:
Trend_biv(xparam, yparam, chartLegend);
Thanks in advance if anyone knows how to do this.
ms
Super User ms
Re: Make Bivariate Invisible for Performance
Use the invisible argument inside the platform call. Try this:
      {Default Local},
                  Dispatch(
                        "Bivar Plot",
                        FrameBox,
                              Column( P_legend ),
                              Color( 1 ),
                              Marker( 1 ),
                              Reverse Scale( 0 ),
                              Excluded Rows( 0 )
            ), invisible // argument placed inside Bivariate()
// just to prove that window exists
wait(5); T_biv<<show window(1);
gzm
gzm
Community Trekker
Simply add the Invisible option to the Bivariate platform call.  See the extension of your example code below.
A couple items to note:
- Using JSL, you can take advantage of Where() commands in most platforms, so that a separate subset table is not required.
- If making many edits to a visible table, dt << Begin Data Update and dt << End Data Update commands can enhance performance as well.
Main_Source = "$sample_data\big class.jmp";
Subset_dt = Current Data Table() << Subset(Sampling Rate( 0.75 ), Stratify(:sex), invisible);
      {Default Local},
            X( Column( xval ) ), Invisible,
                  Dispatch(
                        "Bivar Plot",
                        FrameBox,
                              Column( P_legend ),
                              Color( 1 ),
                              Marker( 1 ),
                              Reverse Scale( 0 ),
                              Excluded Rows( 0 )
Trend_biv("height", "weight", "sex");
(::T_biv << report) << Save Journal("c:\temp\testit.jrn");
//invisible objects (tables and reports) need to be closed to save memory resources
