BookmarkSubscribe
Gil
Gil
Main Effects Power Analysis
Spoiler
I have a question  regarding design evaluation in JMP: when I'm running power analysis for main effects only, the power is higher for these effects then if I would do analysis with 2nd degree interactions. Do you know why the addition of interactions in the analysis will change the power of the main effects?
David_Burnham
Re: Main Effects Power Analysis
Estimating the additional terms is consuming additional degrees of freedom, which will influence the power of estimation
-Dave
David_Burnham
-Dave
Gil
Gil
Thanks David. It was helpful.
