Looping distribution with a data filter
cdwhite
May 3, 2015
Need to create multiple distributions using a variable value to filter the data in a loop.
The example below is an attempt to run a frequency distribution (:RESPONSE) - actually a mosaic chart -  for each condition.  Unfortunately the output is four mosaic charts for the first condition listed ("Mammogram screening"), not a mosaic chart for each condition.  Debugging showed it was running the four iterations.
condition = {"Mammogram screening","Treatment for hearing loss","Fix a broken bone","Lung cancer screening"};
n = N Items (condition);
for (i=1, i<=n, i++,
Current Data Table() <<Data Filter(
Mode( Select( 0 ), Include( 1 ) ),
Add Filter(
columns( :name("Question text") ),
Where( :name("Question text") == condition )
Distribution(
Nominal Distribution(
  Column( :RESPONSE ),
  Frequencies( 0 ),
  Histogram( 0 ),
  Mosaic Plot( 1 )
  Dispatch(
   {"Distributions", "RESPONSE"},
   "Distrib Mosaic",
   FrameBox,
   {Frame Size( 52, 884 ), Left( 0 ), Right( 0 ), Top( 0 ), Bottom( 0 ),
   DispatchSeg( MosaicSeg( 1 ), Cell Labeling( "Show Counts" ) )}
ron_horne
Jun 23, 2011
hi cdwhite​,
i am not sure what you are trying to do.
perhaps you can just use the By option
Open( "$SAMPLE_DATA/Big Class.jmp" );
Distribution( Continuous Distribution( Column( :height ) ), By( :age ) );
ron
cdwhite
May 3, 2015
Your solution worked well. Thank you! Rid of data filter and added “by” statement.
Distribution(
Frequencies( 0 ),
Histogram( 0 ),
Mosaic Plot( 1 )
Dispatch(
"Distrib Mosaic",
FrameBox,
), By( :Question text ));
