BTeague
Looking to bypass or accept duplicate files
I'm currently writing code to pull the files with the same ending into one concatenated file. I'm noticing that when it gets to a duplicate file, the code breaks. Is there a way I could code this to accept the duplicate file as well? I know it may be as simple as renaming the file, but I wanted to reach out for answers first.
If(
	N Items(lotFiles) == 1, CalibrationTable = lotFiles[1],
	N Items(lotFiles) > 1,
		CalibrationTable = lotFiles[1] << concatenate(lotFiles1, create source column);
		For(i = 1, i <= N Items(lotFiles), i++,
			Close(lotFiles[i], nosave)
	N Items(lotFiles) == 0,
		Print("no lot data, please try again");
		Return(0);
Re: Looking to bypass or accept duplicate files
You have a list of files called
     lotfiles
and you reference it using a subscript when referring to a single element, and without a subscript when referencing the entire list.  However, you also have a variable referenced as
  lotfiles1
is this an error?
pauldeen
It looks to me like your second if statement needs work, maybe something like this:
If(
		CalibrationTable = lotFiles[1];
		For(i = 2, i <= N Items(lotFiles), i++,
			 CalibrationTable << concatenate(lotFiles[i], create source column);
		Return(0);
     lotfiles
  lotfiles1
is this an error?
pauldeen
If(
		Return(0);
