BookmarkSubscribe
hrkg
Logistic Regression - complicated situation
Hi ,
Before, I describe my problem, I need to mention that I work with JMP7.
I have a table with 12 columns, the first 6 columns are descriptive parameters for each of the next 6 columns. The first 6 columns are all characters and last 6 columns are all numeric, binomial.
I need to run logistic regression for each of last 6 columns and use the first 6 columns as predictors to extract "Prob>ChiSq" value from "Pearson" test.
Now, I made the following script for one of the "Y,Response" columns :
dt = Current Data Table();
column_names = dt << Get Column Names(Character, String);
results = New Table("Results", Invisible,
                  New Column("Parameter", character),
                  New Column("GEN", numeric),
                  Add Rows(NItems(column_names))
for(i=1,i<=NItems(column_names),i++,
  colName = column_names;
  cmd = Expr(
    ow = dt << Contingency(
                Y( :GEN),
                X( :cName ),
                Contingency Table( 0 ),
                Mosaic Plot( 0 )
                Wait(0.1);
    owr = ow<<report;
    pValueBox= owr[NumberColBox(6)];
    pValue = pValueBox[2];
    Column(results,1) = colName;
    Column(results,2) = pValue;
    ow << Close Window;
    Substitute Into(cmd,Expr(cName),colName);
    Eval(cmd);
results << journal;
Close(results);
When I run it, it works perfectly. Now, if I add next column to script as :
                  New Column("Ne", numeric),
  cmd = Expr(
                Y( :GEN, :Ne),
                X( :cName ),
                Mosaic Plot( 0 )
                Wait(0.1);
    owr = ow<<report;
    pValueBox1= owr[NumberColBox(12)];
    pValue1 = pValueBox1[2];
    Column(results,3) = pValue1;
    ow << Close Window;
    Eval(cmd);
results << journal;
Close(results);
The script stop working. I checked the tree structure and both NumberColBoxes are referring to right values but no journal is created and the script stops working.
Now, my questions :
1) How can I solve my situation when I have static multiple Y values ?
2) Is it possible to define dynamic Y value through a loop ? It becomes complicated for me to have two loops .
I appreciate for any suggestions.
