vikingdash
Local data filter on Run Chart
How can you add a date filter for the X-axis of a Run Chart? I want to show the X-axis only after 3/1/2020.
Re: Local data filter on Run Chart
It looks like you will need to use a Data Filter, not a Local Data Filter
Rows==>Data Filter
Byron_JMP
instead of using a filter, often its much more convenient to just have the chart show the last 50 or so data points.
set up the axis of the graph so that is automatically changes the range Control Charts with a Relative X-Axis Scale
JMP Systems Engineer, Pharm and BioPharm Sciences
