robot
Local data Filter Lost in Platform Script
If I script a graph with a local data filter, I can save the results to a jounal.  But if I do the same thing using Platform(), the filter is not applied.  Why is this?  Is there a good way to script results to a journal without having new windows created?  I am using JMP12.2.
bv = dt << Bivariate(
	Y( :height ),
	X( :weight ),
	Automatic Recalc( 1 ),
	Local Data Filter( Add Filter( columns( :sex ), Where( :sex == "M" ) ) ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				sex,
				Color( 1 ),
				Color Theme( "JMP Default" ),
				Marker( 1 ),
				Marker Theme( "Solid" ),
				Continuous Scale( 0 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
bv << Journal; // Local data filter is applied.
bv2 = Platform(
	dt,
	Bivariate(
		Y( :height ),
		X( :weight ),
			Dispatch(
				"Bivar Plot",
				FrameBox,
				{Row Legend(
					sex,
					Color( 1 ),
					Marker( 1 ),
					Reverse Scale( 0 ),
					Excluded Rows( 0 )
bv2 << Journal; // Local data filter is not applied.
Craige_Hales
Staff (Retired)
Re: Local data Filter Lost in Platform Script
add
bv<<updatewindow;
before the << journal. The Data Filter (and Column Switcher) depend on being updated in a window; the invisible window needs the update too if you run all the statements at once. The platform function doesn't build the window, so the update never happens. There appear to be some other issues there as well. Thanks for pointing this out. I'm adding some notes to the list of things to work on.
Craige
I would assume the issue you are running into is that by the definition of the Platform() function, it is assumed to be called within a defined window.
To answer your question about creating an object without a display window and copying it to a journal:  If what you are attempting to do is to avoid a window popping up before the journal is created, all you have to do is to add the "Invisible" element to the platform invocation.
bv = dt << Bivariate(invisible,
	Y( :height ),
	X( :weight ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Row Legend(
				sex,
				Color( 1 ),
				Marker( 1 ),
				Reverse Scale( 0 ),
				Excluded Rows( 0 )
robot
Thanks, txnelson.  Did you test your script on JMP12.2?  When I run your code, I still get the journal output without the applied local data filter.
Craige_Hales
Staff (Retired)
add
bv<<updatewindow;
Craige
robot
Thanks Craige_Hales.  This worked.
txnelson's solution also worked if I added
Wait( 0.1 );
bv << Journal;
